Chrysler 300 Engine Temperature
Hi, I'm buying a used 2010 Chrysler 300 Touring car and the temp gauge went up to the half-way mark between hot and cold and stayed there during the test drive. I was running the A/C to make sure it worked ok, but it was late in the day and not hot outside. Is this normal? The car I'm replacing is an old Ford where the temp gauge never gets up to the half-way mark unless I'm low on coolant (or oil).
Half way is normal.even little past depending on hot an how hard your driving ..mine runs anywhere between196° -220°.
