Chrysler 300m strange problem... please help
My friend was driving down the road when suddenly, the car starts to slow down, so he pull the car over and as soon as he put the car in park the oil light came on. He turn off the car immidietly after the light came on, after that he gou out from the car and he saw a huge oil leak form the side of the pan, he didnt saw exactly the place that the oil was leaking from but the leak was big, all the oil get drained in 6min. I put extra 3liters of oil and that oil also get drain realy quick.
The car also refuses to start the engine will not crank, i think the computer is not allowing the engine to do that, witch is good. My question is, what could cause that to happen? A loosen oil tap? I donīt know i didnīt see the pan crack, the fire around that or loosen oil filter so is kind of strange. Some idiot told me that it may have a hole in the engine, but he didnt find any oil smell or a smoke. Please help guys |
that idiot I would bank is correct.
Originally Posted by dabbi89
(Post 43249)
The car also refuses to start the engine will not crank, i think the computer is not allowing the engine to do that, witch is good. My question is, what could cause that to happen? A loosen oil tap? I donīt know i didnīt see the pan crack, the fire around that or loosen oil filter so is kind of strange. Some idiot told me that it may have a hole in the engine, but he didnt find any oil smell or a smoke. Please help guys I think he needs to have a professional mechanic look at it at this point. |
Originally Posted by oblivion
(Post 44480)
AFAIK, the computer will not prevent the engine from cranking.
My new 300C dumped all its oil with 32 yes 32 miles on the clock and the dealershio found that the oil filler cap had no seal inside the lid.
Just a thought. Good luck. |
Originally Posted by Tonym410
(Post 45489)
Just a thought. Good luck. So all of the oil in the engine defied gravity and jumped out of the OIL FILLER cap....ok. What engine is this? |
So all of the oil in the engine defied gravity and jumped out of the OIL FILLER cap.. Aside from the obvious you stated......Dont you find it amazing that a 32 mile car can Billow smoke for that long without any attention whatsoever????? A BRAND NEW CAR...and you didnt even pop the hood to see what was burning??????? Sorry to say it Pal, but you deserve what you get..... |
plus if that was the case who ever PDI the car was a slack ass as well if it was missing.
Your responses.
Well thanks for the replies people.
a 3.0 in a 300????
