Dash light prob? HELP!!!!
Ok i have a 2006 300 touring 3.5
Here is my prob. The light for the A/C and fan and Where the air goes does not work. All the other lights do. I CANT find the fuse for it. WHERE is IT!!! thanks for the help Dave Did i tell you i HATE elec probs. |
no fuse all power from the same source the cluster
if no lights work I would say U have a bad ac control head. |
Huu the A/c works Good
Just cant see what your doing at night. on all 3 knobs speed of fan/ AC temp/ or Ac placement Just no light on any of them A bad bulb? |
oh by the way the ash tray sig lighter was bad but i fixed that all went out same time
If that hepls? |
Not sure about your model but the way these things usually work is that the bezel that surrounds the control head usually snaps in place and can be removed by prying it off. DON'T use a screwdriver. Get a set of plastic trim tools to pry gently on the bezel. Once the bezel is off you should be able to see how to remove the control head. Sometimes the control head comes off with the bezel. Like I said, I'm not familiar with your model but these things are designed to be built quickly on the assembly line and they like to use snap-together components.
You won't see the bulbs when you look at the back of the unit, but you'll probably see small circular things with a screwdriver slot in them. If you turn the things with a screwdriver counterclockwise, they come out and you find that they are the base of a bulb. The bulb plus base can be bought at the dealership. Before you start, go over the the dealership and talk with the guy at the parts counter. Tell him you want to replace the bulbs in the heater control and ask him to look them up in his parts catalogue on his computer. There are usually exploded diagrams of the whole thing and you can figure out how it goes together from a quick look at the diagram. Maybe someone who is more familiar with the 300 will chime in here. |
can someone show me the back of the 3 switchs for a 300 ac fan ac temp and ac heat air location
not replaceable let me know when some one is gonna listen to me
Well its not like that but i hear they are just LEDs.
So it looks like i need a new cluster for the ac How much do you think they are? |
call the dealer
