ERRATIC IDLE 05 LX 5.7 ONLY
IF YOU HAVE A 05 LX WITH A MID TO EARLY BUILD DATE AND HAVE AN ERRATIC IDLE AT LIGHTS HAVE SOMEONE CHECK THE MAP SENSOR. THE PINS MIGHT BE CORROIDED, AND TO ADD THE PART HAS SUPERCEADED A FEW TIMES. WE HAVE A FEW WITH THIS ISSUE AND WAS ADVISED BY ENGINEERING TO LOOK AT MAP AND PURGE ISSUES. THIS IS ONLY ON 2005, ON 2006 THEY USED A DIFFERENT MANU. FOR THE CAM AND DIFFERENT SOFTWARE. IF YOU HAVE AN 06 AND HAVE THIS ISSUE THERE COULD BE A PROBLEM. I WAS ALSO TOLD THAT TARGET IDLE ON THE 5.7 AND 6.1 IS KEPT LOW FOR THE FACT OF EPA ISSUES. LOL
JUST A HEADS UP TO ALL. XTREME |
RE: ERRATIC IDLE 05 LX 5.7 ONLY
HI, does this mean that under FLORIDA temperatures the engine can cut off at traffic lights
and pulling up after a stand still. |
how many miles on it? over 30,000.... Time for new plugs.........
