-   Chrysler 300, 300C & 300C SRT-8 (https://www.chryslerforum.com/forum/chrysler-300-300c-300c-srt-8-17/)
-   -   Location of oil pump and fuel pump on 2005 300 (https://www.chryslerforum.com/forum/chrysler-300-300c-300c-srt-8-17/location-oil-pump-fuel-pump-2005-300-a-12588/)
Darth Menace Oct 2, 2010 05:06 PM
Hey guys, my dad has a 2005 Chrysler 300 (3.5 L), and when he starts his car it ticks for a little bit. This being said he wants to replace the oil pump in hopes this helps the problem.
Where is the location of the oil pump for this car? Also, where is the location of the fuel pump?
thanks in advance
CHRYSLER TECH Oct 2, 2010 06:33 PM
humm a good waste of money
REMOVAL
Drain the cooling system. (Refer to 7 - COOLING - STANDARD PROCEDURE)
Remove the timing belt. (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL)
Remove the crankshaft sprocket. (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL)
Remove the oil pan. (Refer to 9 - ENGINE/LUBRICATION/OIL PAN - REMOVAL).
Remove the oil pickup tube (WINDAGE TRAY AND OIL PICK UP TUBE).
Remove the oil pump fasteners. Remove the oil pump(OIL PUMP AND CRANKSHAFT GEAR) and gasket from engine.
charles92154 Feb 18, 2016 10:36 PM
as for the fuel pump, itself, is on right side under back seat..the fuel filter, fuel press. regulator, is on left side, and also fuel level,gauge...i'm going thru same, well with a 300 like yours and my durango. i'm in the process of checking, relay, and fuze, i dont hear anything from pump when i turn on key. good luck..
UltraNutZ Feb 19, 2016 07:21 AM
6 year old thread?:confused:
CHRYSLER TECH Feb 19, 2016 09:16 PM
better late then never??
