P1005 error code ?
what does this mean? how can I get if fixed??
car broke whats wrong
I wish i have 1 cent for every time i heard that how do u expect any one in the world to help out if we dont even know what kinda car this is???? |
chrysler 300 touring, 2007, 3.5 6cyl
P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
When Monitored: With the engine run time above a calibrated value, battery voltage greater than 10.4 volts, ECT within a specific range, and the Manifold Tune Valve Assembly control active. Set Condition: This PCM compares the circuit feedback to a calibrated closed range when the circuit is de-energized or to a calibrated open range when the circuit is energized. If the value is determined to be out of the calibrated range in either the de-energized or energized state for more than a calibrated amount of time, this DTC will set. Possible Causes INTERMITTENT DTC (K136) MTV CONTROL CIRCUIT SHORTED TO VOLTAGE (K136) MTV CONTROL CIRCUIT SHORTED TO GROUND (K136) MTV CONTROL CIRCUIT OPEN OR HIGH RESISTANCE (Z816) GROUND CIRCUIT OPEN OR HIGH RESISTANCE MANIFOLD TUNE VALVE ASSEMBLY POWERTRAIN CONTROL MODULE (PCM |
