Removing upper console
How do you remove the upper console |
RE: Removing upper console
what is an upper console to u??? dash or arm rest ??? center console where radio is at
Where the sun roof contol andglass holder, console
ther over head console correct???
[ol][*]Disconnect and isolate the battery negative cable.[*]Pull downward on the sides of the overhead console housing firmly and evenly to disengage the snap clips from the overhead console bracket[*]Lower the overhead console from the headliner far enough to access the wire harness connectors (2).[*]Disconnect the roof wire harness connectors (2) from the overhead console wire harness connector.[*]Remove the overhead console from the headliner.[/ol] |
