Right high beam not working after replacing the bulb and fuse
Good afternoon/evening everyone.
I have 2007 Chrysler 300 , v6 2.7. the right side high beam is not working. I replaced the bulb, checked the fuses and still not working. Anyone has/had a similar issue? https://cimg1.ibsrv.net/gimg/www.chr...e1e9227aa0.jpg Thanks |
Had a similar issue on an '06 Charger with the left side high beam. The problem was with the ground wire where it was spliced into the chassis ground. The chassis ground should be close by but it is a bit of a pain to trace and access. Patience is required.
Originally Posted by ggoose
(Post 124085)
I just came home from my local mechanic who said that there's a power but once he "plugs the bulb the power go to the ground". He said he'll trac the wire because its damaged somewhere. |
