seat belt chime
Hi
I'm considering leasing a 2016 Chrysler 300 limited. Wondering if the procedure i've found on the internet will work on a 2016 300 ? Here's the procedure BeltAlert® Programming Note: Chrysler Group LLC does not recommend deactivating the BeltAlert®. The BeltAlert® can be enabled or disabled by your authorized dealer or by performing the following steps: With all doors closed, and the ignition in any position except ON/RUN or START, buckle the driver's seat belt. Cycle the ignition to the ON/RUN position, but do not start the engine. Wait for the Seat Belt Reminder Light to turn off and then proceed to the next step. Note: You must perform the following steps within 60 seconds of cycling the ignition to the ON/RUN position. Within 60 seconds of cycling the ignition to the ON/RUN position, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds, ending with the seat belt buckled. Note: Watch for the Seat Belt Reminder Light to turn on while unbuckling the seat belt and turn off while re-buckling the seat belt. It may be necessary to retract the seat belt. Cycle the ignition to the OFF position. A single chime will sound to signify that you have successfully completed the programming. BeltAlert® can be reactivated by repeating this procedure. Note: Although BeltAlert® has been deactivated, the Seat Belt Reminder Light will continue to illuminate as long as the driver's seat belt is unbuckled. .....Thanks :( |
