| coolmoss |
Jul 16, 2023 07:59 AM |
Tight steering after reinstalling SCCM
Hello, I'd appreciate any ideas or help :)
I have a 2005 300. I was going to replace the multi-function switch (turn signal switch) because the left blinker light wasn't returning to center. Upon removing the steering wheel and SCCM I found it wasn't the switch that was the problem, but rather the clockspring inner diameter where the plastic tabs are. Found one chunk broken off and others badly worn. I've temporarily reassembled so I could still drive while waiting for new clockspring (of course clearing out any broken off bits and debris) but now the steering is really heavy. I also can hear something rubbing inside the steering column cover (where the SCCM lives). I did this work really carefully and am a pretty experienced mechanic. I've had it apart and back together a few times, and I'm really scratching my head. Nothing under the hood was touched, nothing was forced, bent, pushed or hammered on. It all came apart and went back together quite easily. Thanks in advance for any advice.
