'07 Aspen 4.7L Towing Capability
I read online that a "properly equipped" Aspen with the 4.7 liter V8 can tow 7500lbs.
Problem is, I can't find out what constitutes "properly equipped." I have the Aspen Limited 2WD, with the 4.7l engine. I don't know of anything extra on this car, and am thinking of using it to tow a camper and/or a boat (not together). It did not come with the tow package option, but I've found a nice frame-mounted Class 3 hitch assembly made for the Aspen. For an added measure of safety, I'm limiting my tow weight to around 4500, which would be 60% of listed capacity. Maybe a couple hundred more, but never over 4800lbs. Would I need to beef up the rear shocks or springs? Anything else I need to look at or modify on the Aspen to ensure a dependable, safe, tow? |
The 4x2 model tows more than the 4x4, so that's part of the "properly equipped" equation. The other part is probably the tow package, which includes the hitch and wiring harness, and a heavy-duty service group that includes a transmission cooler and power steering cooler. If you have the 4x4, the tow package also comes with the skid plate group.
There must have been changes between the 07 and 08 model, because the 08 4.7 (4x2) only tows 5,950 (max. trailer weight). The stock shocks are junk on the Aspen. I upgraded to Bilstein HD, and they've been much much better. I'm sure they would also do well with towing. |
Ahhh, forgot about a tranny cooler! Thanks for reminding me.
I think I found a good hitch. A CURT model 13296, which is a Class III, and bolts directly onto the frame.
Now, a little confused about the tow ball mount, and how much of a "drop" I should get. Intended purpose will be for towing a boat. I'm thinking a 2" or a 4" drop. What is everyone else using? |
Randy,
If you would like to send me the last eight characters of your VIN number, I would be happy to provide you with a build sheet and advise you of the tow specs for your vehicle. |
Originally Posted by ChryslerCares
(Post 71176)
Randy,
If you would like to send me the last eight characters of your VIN number, I would be happy to provide you with a build sheet and advise you of the tow specs for your vehicle. 7F557325 |
VIN 1A8HX58N07F557325
Vehicle Description CHRYSLER ASPEN LIMITED 4X2 SPORT UTILITY 4-DOOR Model Year 2007 Body Model HG 1 P 74 Sales Code --- Description *S7 Cloth Bucket Seats -DB Dk/Lt Slate Gray AFHS Interior Convenience Group APAS Monotone Paint AWRS Ambient Light Group BABS 160 Amp Alternator BCQS 750 Amp Maintenance Free Battery BCSS Battery Run Down Protection BNBS Electronic Stability Control BRTS Anti-Lock 4-Wheel Disc Brakes CACP Low Back Bucket Seats CBZS Prem Vinyl Door Trim w/Map Pocket CFPS 3rd Row Seat CFQS 2nd Row 40/20/40 Folding Seat CGSS Supplemental Side Air Bags CG3S Advanced Multistage Front Air Bags** CJ5P Supp. Side Curtain All Rows Air Bags CKAS Carpets - Floor and Cargo Area CKTS Cargo Tie Down Loops CSRS Passenger Assist Handles CUNS Overhead Console CURS Rear Compartment Storage Tray CVMS Full Length Flr Console Prem Arm/Rest DGQ 5-Spd Automatic 545RFE Transmission DMDS 3.55 Rear Axle Ratio DRBS Corporate 9.25 LD Rear Axle EVA 4.7L V8 MPI Engine GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEGS Deep Tint Sunscreen Glass GFAS Rear Window Defroster GNAS Rear View Day/Night Mirror GNCP Sun Visors w/Illum Vanity Mirrors GTSS Power Heated Mirrors, Fold-Away GXRS Keyless Entry GXXS Sentry Key Theft Deterrent System HAAS Air Conditioning HBBS Rear Air Conditioning w/Heater JAMS Soft Touch Instr. Panel w/Woodgrain JA2S Instrument Cluster w/Tach JBGS Instrument Panel Woodgrain Bezel JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers JHDS Rear Var Intermittent Wiper/Washer JJBS Dual Note Electric Horns JJJS 12V Power Outlet Mounted in IP JJMS Auxiliary 12-Volt Rear Power Outlet JKPP 12V Auxiliary Power Outlet JKVS 115V Auxiliary Power Outlet JNBP Instr Pnl w/Ambient Lighting Bezel JPBS Power Locks JPVS Power 8-Way Driver Seat JP3S Pwr Front Windows, 1-Touch,Up & Down LABS Tire Pressure Monitoring Warning LP LACS Illuminated Entry LAFS Key in Ign/Seat Belt Warning Buzzer LAJS Headlamps On Warning Chimes LALS Low Washer Fluid Warning Signal LAMS Door Ajar Warning Lamp LANS Decklid/Liftgate Ajar Warning Lamp LAZP Vehicle Information Center LBPP Liftgate LED Lamps LBRS Front & Rear Aimable LED Lamps LCEP Rear Courtesy/Reading Lamps LMBS Halogen Headlamps LMGP Automatic Headlamps LNJS Fog Lamps LPSS CHMSL Lamp LSAS Security Alarm MCXS Body Color Fascias w/Bright Insert MDAS Front License Plate Bracket MFMS Black/Bright Grille MHAS Black Windshield Moldings MJBS Chrome Bodyside Molding MMSS Bright Belt Moldings MNCS Bright Door Handles MNPS Bright License Plate Brow MVAS Limited Badge MV9S Pro 4X Decal MWHS Rear Wheelhouse Liners MWPS Body Color/Bright Side Roof Rails MYRS Aspen Badge NAE California Emissions NFJS 27 Gallon Fuel Tank NHMS Speed Control NZDS Next Generation Engine Controller PDM Mineral Gray Met. Clear Coat RCDS 4 Speakers RDDS Fixed Long Mast Antenna RDZS Steering Wheel Mounted Audio Ctrls REFS AM/FM Compact Disc Radio SBAS Power Rack and Pinion Steering SCKS Luxury Steering Wheel SDBS Heavy Duty Suspension SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers SHCS Front and Rear Stabilizer Bars SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch TP5S P265/60R18 BSW On/Off Road Tires TZAP Goodyear Brand Tires WF1P 17" Steel Spare Wheel WPRS 18X8.0 Aluminum Wheels XA8S Non Adjustable Pedals XBNS Tip Start XDXS Scissor Type Jack XGDP Universal Garage Door Opener XGQS Synthetic Rear Axle Lube XGWP Stain Repel Seat Fabric XSLS Brake/Park Interlock X81S Instrument Panel Parts Module X88S Tire & Wheel Parts Module YAAS Build To U.S. Mkt. Specifications ZBAP Spring - Left Front ZBRP Spring - Left Rear ZPAP Spring - Right Front ZPRP Spring - Right Rear Z1DS GVW Rating - 6450# 4FJA Fleet Daily Rental W/Client Code 5I2S Two Wheel Drive (2WD)/(4X2) Maximum Trailer Weight = 7350 lbs Gross Vehicle Weight Rating (GVWR) = 6500 lbs Payload = 1501 lbs Curb Weight = 4999 lbs Gross Combination Weight Rating (GCWR) = 12500 lbs |
Thanks so much for all that info!
So now I know for sure that my Aspen can tow up to 7350lbs. I'll definately be getting a heavy duty aux tranny cooler and beefier rear shocks. Maybe even some helper springs, though I might find the ride a bit too stiff when not towing anything (which will only be the occasional need). I'm still going to do my best to limit the total tow weight to around 4500lbs (60%) so I don't put that much strain on the auto tranny. |
I'd like a build sheet too!
Hello,
I'm new to the forum so please forgive me if I'm doing this wrong. I am considering an '08 Aspen Limited 4.7 RWD for towing a new 19' Shasta camper that weighs 3300 lbs wet. I'd like to get a build sheet for it from Chrysler Cares. The last 8 of the VIN are: 8F134221. I am finding that all the Aspens that I've looked at have tranny coolers and a tow/haul button on the gear shift selector regardless of if it has a hitch or not so am I to assume that they all came this way with a "Tow Prep" Package? If so can I bolt on a Class III hitch on it and add a 7-pin plug and a brake controller and be good to go? I am hoping to make an offer on it soon. Thank you so much! |
towing as well
Originally Posted by Dave Blarge
(Post 89850)
Hello,
