07 Chrysler Aspen has a NO FUSE error message
My husband and I need some help -- we love you 07 Chrysler Aspen, but have an issue. The car will not start, will not turn over, and has an error message "NO FUSE". My husband discovered that the fuse panel in the vehicle below the steering wheel was wet (we think we have a leak in the sunroof and it's traveling down the door panel).
We don't want to have the vehicle towed, and want to fix/replace the fuse that is out. Where is the fuse panel under the hood? What fuse would it be? My husband cleaned off the fuse panel last night and it started this morning, but will not start for me now. Please help! Thanks Christy.:eek: |
It sounds like you already know what the problem is -- a wet fuse box causing intermittent shorts. You need to get the leak repaired, and pull/check the fuses in the box that was wet.
The same error message can sometimes happen with a dead/dying battery. |
