-   Chrysler Aspen (https://www.chryslerforum.com/forum/chrysler-aspen-41/)
-   -   2007 Aspen MyGig RHR upgrade, backup camera question? (https://www.chryslerforum.com/forum/chrysler-aspen-41/2007-aspen-mygig-rhr-upgrade-backup-camera-question-19230/)
Sessholvlaru Mar 1, 2013 10:01 PM
I recently traded in my 2011 Challenger R/T for an extra clean brilliant black '07 Aspen for several "practical" reasons.
Now I have an RHR MyGig which needs to go into the Aspen, compliments of the Lockpick adapter.
I have sourced pretty much everything I need but the one thing I can't find an answer to is whether or not I can use the factory backup cam with the RHR/Lockpick.
My truck did not come with the OEM cam and for reasons of anal-retentiveness I don't want to install an aftermarket camera when an OEM bolt-in part exists.
Does anyone know if I can splice the OEM camera into a, AV harness to fit the Lockpick? It looks like the aftermarket camera has two wires and the OEM has three?
Ponderosa340 Jul 11, 2014 04:33 PM
I'm hoping to upgrade to a MYGIG system. I also have a black 07 Aspen with UConnect, Nav and VES. Does anyone know which MYGIG system I should be looking for? It seems I will have to buy the LockPick adapter but after what it costs for the MYGIG system a few hundred more won't be too much of a stretch.
Will Murray Apr 26, 2018 07:48 AM
Epic waste of time
Why did you not just buy the newer model antenna? It’s $25-$30 on eBay used and takes all of 5 seconds to grind the tab so it’ll fit the hole of the older Chrysler vehicles. The connectors at the back of the vehicle are the same... that’s why I did with my 2008 Sebring hard top convertible when upgrading to the RHR...
Will Murray Apr 26, 2018 07:50 AM
Epic waste of time
Why did you not just buy the newer model antenna? It’s $25-$30 on eBay used and takes all of 5 seconds to grind the tab so it’ll fit the hole of the older Chrysler vehicles. The connectors at the back of the vehicle are the same... that’s what I did with my 2008 Sebring hard top convertible when upgrading to the RHR...
Will Murray Apr 26, 2018 07:51 AM
Remove double post.
sorry double post
Will Murray Apr 26, 2018 07:52 AM
sorry double post
