-   Chrysler Aspen (https://www.chryslerforum.com/forum/chrysler-aspen-41/)
-   -   2009 Aspen Hybrid radiator fan problem (https://www.chryslerforum.com/forum/chrysler-aspen-41/2009-aspen-hybrid-radiator-fan-problem-31481/)
James Buchy Jan 5, 2020 02:30 PM
Hi
My employer has asked me to look into a problem with his 2009 Aspen Hybrid. The radiator fan will not stop after the vehicle is shut off. it will keep running at full speed until the battery dies or is disconnected. Because there were so few built I am having a real hard time finding anyone with information. Does anybody here have any suggestions?
TeamE Apr 21, 2020 07:22 PM
Fan running after shut off, draining battery
Did you get an answer to your problem? I seem to be experiencing the same with my 2009 Hemi Hybrid. Thanks for any input.
Genghis May 25, 2020 08:29 PM
Fan wont turn off
Hi all, I am having the same issue with my 2009 Aspen Hybrid. It first started as a dead battery, then still occurs now after replacing the battery. I removed both relays titled rad fan low and rad fan high with no change, the fan remains running.
If anyone has managed to figure this out, would appreciate any guidance.
Many thanks
Aenglese May 26, 2020 05:27 AM
I took mine to chrysler
They said I need to replace the hybrid gateway module and the cooling fan - I don’t think the cooling fan has an issue because that is running right but it’s signal is coming from the gateway module (not a mechanic but)
Aenglese Jun 8, 2020 09:37 AM
so check this out —-> I have your solutions it’s two parts it’s the gateway module and the hybrid cooling fan BUT THEY DONT MAKE THE HYBRID COOLING FAN ANYMORE so what you can do which is what I’m doing is taking part 55361429AC and using the housing but replacing the fan inside of it with the fan of a bmw 600w fan motor so it will work
