Aspen LED Headlight & Turn Signal Bulbs
Has anyone found any LED headlight bulbs that work without flickering while turned off?
Has anyone found any LED turn signal bulbs that do not create hyper flash? Do I need to change out a relay to make LED bulbs work? |
I installed a set of these Beamtech bulbs from They did dimly flicker for a bit when I turned them off. I contacted manufacturer and they sent me a couple of resister packs which you simply plug in line and that resolved the issues.
I believe with any turn signal bulbs you will also have to install resistor packs. You shouldn't have to replace a relay though. |
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Many people pay attention to the fact that for some reason the LED lamp flickers when on and off.
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Many people pay attention to the fact that for some reason the LED lamp flickers when on and off. This disadvantage is manifested due to unstable power supply, which passes ripples from the 220 volt network. It manifests itself in budget and inexpensive Chinese ones, in which the manufacturer saved on the power source. Therefore, it is really very important to buy only high-quality LEDs, even if they are a little more expensive. For example, my car has explosion proof lighting paint booths. Since they are durable, they will shine not only for you, but also for your children, and can be inherited. When buying, you do not spend, but basically save your money.
Originally Posted by Changingminds
(Post 122017)
