Build Sheet Needed
I bought a 2009 Chrysler Aspen With The 5.7 Hemi......The used car dealer told me this Aspen was the most optioned Aspen Made. I don't really believe him but if you could provide me with the build sheet it would help....the vin# is 1A8HW58T89F705905.....Thanks Again
Just did a search and found a site to pull up build sheets for Ram trucks (built after 1998). I tested with your VIN and surprise, it works for us too. Not as detailed as some I've seen before because it doesn't include the package sales codes, but it does list a lot. The biggest features I do not see listed for your Aspen is Heavy Duty Service Group and Trailer Tow Group. These packages include transmission cooler, power steering cooler, skid plates, tow hooks, receiver hitch and wire harness. So from what I can tell you do not have those. You do however have Memory seats, mirrors & pedals, Navigation, Bluetooth connect and subwoofer. A few features I wish mine had. :(
Go to Ram Trucks site : Ram Trucks - Contact Us and then click on "Equipment Listing", Key in your VIN in the little box and hit search. Voila. Here is what they said about yours: VIN - 1A8HW58T89F705905 Vehicle Description - 2009 CHRYSLER ASPEN LIMITED 4X4 SPORT UTILITY 4-DOOR Standard Equipment: * Interior Convenience Group * Monotone Paint * Ambient Light Group * 160 Amp Alternator * 750 Amp Maintenance Free Battery * Battery Run Down Protection * Electronic Stability Control * Anti-Lock 4-Wheel Disc Brakes * Prem Vinyl Door Trim w/Map Pocket * 3rd Row 3-Pass 60/40 Split Seat * 2nd Row 40/20/40 Reclining Seat * Supplemental Side Air Bags * Advanced Multistage Front Air Bags * Carpets - Floor and Cargo Area * Cargo Tie Down Loops * Luxury Front & Rear Floor Mats * Passenger Assist Handles * Overhead Console * Rear Compartment Storage Tray * Full Length Flr Console Prem A/Rest * 205MM Front Axle * 3.55 Rear Axle Ratio * Corporate 8.25 Rear Axle * Tinted Windshield Glass * Front Door Tinted Glass * Deep Tint Sunscreen Glass * Rear Window Defroster * Keyless Entry * Sentry Key Theft Deterrent System * Rear Air Conditioning w/Heater * Soft Touch Instr. Panel w/Woodgrain * Instrument Cluster w/Tach * Instrument Panel Woodgrain Bezel * 120 MPH Primary Speedometer * Var Intermittent Windshield Wipers * Rear Var Intermittent Wiper/Washer * Dual Note Electric Horns * 12V Power Outlet Mounted in IP * Auxiliary 12-Volt Rear Power Outlet * 115V Auxiliary Power Outlet * Power Locks * Pwr Front Windows, 1-Touch,Up & Down * Power Liftgate * Illuminated Entry * Key in Ign/Seat Belt Warning Buzzer * Headlamps On Warning Chimes * Low Washer Fluid Warning Signal * Door Ajar Warning Lamp * Decklid/Liftgate Ajar Warning Lamp * Front Passenger Seat Belt Alert * Front & Rear Aimable LED Lamps * Halogen Headlamps * Fog Lamps * CHMSL Lamp * Security Alarm * Body Color Fascias w/Bright Insert * Front License Plate Bracket * Grille-Black/Bright * Black Windshield Moldings * Chrome Bodyside Molding * Bright Belt Moldings * Bright Door Handles * Bright License Plate Brow * Limited Badge * Chrysler Badge * Rear Wheelhouse Liners * Body Color/Bright Side Roof Rails * Aspen Badge * 27 Gallon Fuel Tank * Speed Control * Electronically Controlled Throttle * Next Generation Engine Controller * Cool Vanilla Clear Coat * Fixed Long Mast Antenna * Steering Wheel Mounted Audio Ctrls * SIRIUS Satellite Radio * Power Rack and Pinion Steering * Luxury Steering Wheel * Heavy Duty Suspension * Front Heavy Duty Shock Absorbers * Rear Heavy Duty Shock Absorbers * Front and Rear Stabilizer Bars * Tilt Steering Column * Full Size Spare Tire * ParkSense Rear Park Assist System * ParkView(TM) Rear Back-up Camera * Tip Start * Scissor Type Jack * Synthetic Rear Axle Lube * Brake/Park Interlock * Instrument Panel Parts Module * Tire & Wheel Parts Module * Build To U.S. Mkt. Specifications * GVW Rating - 6650# * U.S. Dealer Retail * Zone 32-New York * Four Wheel Drive (4WD)/(4X4) * 2009 Vehicle Specifications * HG-Vehicle Family * Vehicle Order Tracking * U.S. Specifications Label * New Jersey Ship to State Code * New Jersey Sold to State Code Optional Equipment * Leather Trimmed 1st & 2nd Row Seats * Light Graystone * Low Back Bucket Seats * Supp. Side Curtain All Rows Air Bags * All Automatic Transmissions * 5-Spd Automatic 545RFE Transmission * Elec Shift-on-the-Fly,F/Time T/Case * 5.7L V8 HEMI MDS VVT Engine * Laminated Front and Rear Door Glass * Sun Visors w/Illum Vanity Mirrors * Rear View Auto Dim Mirror * Auto Dim Exterior Driver Mirror * Power Sunroof * Power 6X9 Multi-Func F/Away Mirrors * Air Cond ATC w/Dual Zone Control * 12V Auxiliary Power Outlet * Instr Pnl w/Ambient Lighting Bezel * Pwr 8-Way Drvr Mem 4-Way Pass Seats * Heated Front Seats * Vehicle Information Center * Liftgate LED Lamps * Rear Courtesy/Reading Lamps * Exterior Mirrors w/Memory * Radio/Drvr Seat/Mirrors/HVAC Memory * Automatic Headlamps * Body Color Running Boards * 50 State Emissions * Exterior Mirrors w/Heating Element * Cool Vanilla Clear Coat * 368 Watt Amplifier * Uconnect 730N CD/DVD/MP3/HDD/NAV * 8 Alpine Speakers W/Subwoofer * Uconnect Voice Command w/Bluetooth * SiriusXM Traffic * Sirius Backseat TV * Tire Carrier Winch * P265/50R20 BSW All Season Tires * Goodyear Brand Tires * 17" Steel Spare Wheel * All Aluminum Wheels * 20X8.0 Aluminum Chrome Clad Wheels * Power Adjustable Pedals w/Memory * Remote Start System * Universal Garage Door Opener * Tire Pressure Monitoring Display * Locking Lug Nuts * Rear Seat Video System * For More Info, Call 888-539-7474 * 1-Yr. SiriusXM Radio Service * 1-Yr. SiriusXM Traffic Service * 1-Year SIRIUS Backseat TV Service * 3.2 Additional Gallons of Gas * Spring - Left Front * Spring - Left Rear * Spring - Right Front * Spring - Right Rear * Customer Preferred Package 2TJ * Customer Preferred Package 28J * Includes Full Tank of Fuel * September Production * New Jersey Cost Surcharge |
Thanks Calamity Coyote
Thanks Calamity Coyote for all your help.....That was alot of info on this Aspen that we were unaware of....This is a great website if you have problems or questions about a vehicle....I just want to say Thank You Again
Not sure if this site was available back when this was posted, but you can find all this info on the mopar.com site now:
https://www.mopar.com/chrysler/en-us...equipment.html Then look under the Standard and other tabs to see your equipment. |
Re: original Aspen MPG question...
I see this is an old thread but for what it's worth today I get 22 MPG at 65 MPH (2,000 RPM) and 20 MPG at 73 MPH highway cruise. Around town, not so good at maybe 13 MPG. 2007 Aspen 5.7 with 3.92 rear end, 115K Miles, tires DUELER H/L ALENZA PLUS P265/50R20 106V |
