Chrysler Aspen idling bounce
Old Jun 11, 2012 | 07:26 AM
dyson77's Avatar
Default Chrysler Aspen idling bounce
Hey Guys i have a 2007 Chrysler aspen 4x2
I have been very pleased with the truck until now.
I have been having a issue with the idle. It will normally idle around 5rpm. but lately it will "bounce" between 5 and 10 and you can feel it going up and down. it will happen for a while and then sometimes stall out. it will start right back without a issue most times a very small amount of times it will take a few tries to start.
I took it to my mechanic and he said he couldnt find the problem. This is my wife and kids daily truck so i need to get this fixed asap
Not sure if this has anything to do with anything but I get the check engine issue a very few times its always the gas cap is loose error. My wife said she puts it on right but it never happens when I put gas in.
Old Jun 20, 2012 | 08:17 PM
fledda's Avatar
Could be the Throttle Position Sensor.
Old Jun 27, 2012 | 07:22 PM
15951a\'s Avatar
Is the code P0457 or P0455?
If it's P0457, loose gas cap. If it's P0455, something's up with the Evap purge system. Sounds like the latter given your other symptoms.
Old Apr 23, 2015 | 10:47 AM
Gaugler11's Avatar
Default Idle air control valve
Took me awhile to discover that this was the problem on our Aspen. Tach would 'bounce' around like you said, especially at traffic lights, drive thrus, etc. replacing the idle air control valve did the trick! Not expensive, easy DIY job
phillips1114
Jun 18, 2011 01:50 PM
tlc3152
12
Sep 28, 2007 12:06 AM
soldier51
May 27, 2007 04:08 PM
oliver815
Feb 12, 2007 11:47 AM
oliver815
