-   Chrysler Aspen (https://www.chryslerforum.com/forum/chrysler-aspen-41/)
-   -   Idling Problems (https://www.chryslerforum.com/forum/chrysler-aspen-41/idling-problems-4757/)
sumcerious Feb 8, 2008 05:21 PM
Idling Problems
I have 3300 miles on my 2007 Aspen.When I reached approx. 900 miles I began noticingrough vibrations when braking at red lights.It started out happeninginfrequently, but now it's all the time. I took it to the shop several times to have the idling system checked and they told me that it was designed like this. Has anyoneelse experienced this problem?
valleybill55@aol.com Feb 8, 2008 05:41 PM
RE: Idling Problems
i have about the same amount of miles on my 2008 with the hemi, no problems yet.
jimhild Feb 8, 2008 05:45 PM
RE: Idling Problems
We have just over 10,000 miles on ours and no issues of any kind. Try another dealer and try another brand of gasoline.
sumcerious Feb 8, 2008 06:05 PM
RE: Idling Problems
I tried changing the gas (started using 93)and still no change. I was told by the service tech that "all the Aspens/Durangos were designed to idle at 500 rpm which makes a rough ride while waiting at lights." I justwanted to get some feedback from other owners; as I can see "everybody" is not having this problem.
jimhild Feb 8, 2008 06:31 PM
RE: Idling Problems
Our Aspen is gone this weekend, but when it gets home I will check the idle speed at a traffic light, I think it is about 600-625 rpm. Will let you know, but it is very smooth at idle.
valleybill55@aol.com Feb 9, 2008 09:26 AM
RE: Idling Problems
r.p.m. 600 maybe a little over 600 the idle is very smooth.
luv2byte Feb 9, 2008 12:06 PM
RE: Idling Problems
When sitting idol you cannot even tell my Aspen is even on, I have an 2007 4.7.
jimhild Feb 12, 2008 02:10 PM
RE: Idling Problems
Just got the Aspen back to check RPM. Idles between 600-625 with A/C on, transmission in drive and stopped at traffic light.
Very smooth idle, no issues at all.
sumcerious Feb 13, 2008 02:21 PM
RE: Idling Problems
What is your rpm at traffic lights without the AC on? I was informed that the rpm would increase if theACis on. Riding around with the AC on iswhat they suggested that I do if I wanted to stop the car from shaking. So if you stop at a light with the AC on you should notexperience a problem.However,if you turn the AC off and you stop at a light the rpm would decrease to500rpm and you would experience a rough idle.
My rpm at traffic stops without the AC on is 500 rpm.
jimhild Feb 13, 2008 03:17 PM
RE: Idling Problems
I will be out in about an hour and will try with A/C turned off.
