no rear AC
The front AC works on my 2007 Aspen, but when I try to use rear AC - nothing!
can u be a bit more specific?
I can use the front AC but if I put knob on rear AC nothing happens. I assume the system works but when trying to use rear AC nothing happens-no air at all!
have u read the owners manual for the operation on how to use the rear air system?
have had Aspen for 3 years; AC used to work in the rear and now it doesn't. Is there a particular fuse that I might check?
can u put it on manual mode and use the switch in the back?
It might be helpful to share more info so Chrysler Tech can help you - things like whether you have the automatic or manual a/c system, if you've tried to use the switch back there in the 2nd row, etc.
turns out it was a short and has been repaired-thank you for your responses on this forum!
