Power Window Issues
My passenger side window will not roll up or down when I press the driver side switch. When I press the passenger side switch it will only work sometimes. I hear a couple clicking sounds when I press either switch. Any help would be greatly appreciated.
needs new window motor more then likely,do you hear a click when you push up and down ? if its clicking its getting power before you go buying a window motor cheek to see if its off track
Power Window Issues
Yes, it clicks when I press up or down on the switches.
ok it could only be bad window motor or off track
Power Window Issues
I ordered a regulator with motor from the dealer. Will take it a part next week and see if I need to replace it. Hopefully it will just be off track. I will keep you posted. Thank you
your very welcome Fresh,,,
