Stuck wheel hub bearing
Doing complete Brake job on Aspen Left front dust shield is rusted really bad caused by caliper stuck two years ago( got really hot replaced caliper with reman caliper ,rotor and pads are shot after 20,000 miles installing new brake hose also) . So have to pull bearing to replace dust shield but cannot get bearing out Trying to save it if possible. Any tricks out there?
a slide hammer will get it off
Got the bearing out, but ended up taking knuckle off vehicle and using longer bolts to hit on with small sledge from the back side of knuckle. Well after cleaning up aluminum corrosion on the knuckle the bearing is too loose in knuckle. So have new OEM knuckle,bearing and dust shield ordered. The heat from the stuck caliper really did a number on the Knuckle.
Originally Posted by purplepuller
(Post 95608)
Got it all together over the weekend. New pieces go together nice! Put the Powerstop brakes on it.
