Window Up issue
Hi guys my 07 Aspen drivers side front window won't close all the way when I use the "Automatic up" feature. It will go all the way up, and then back down 2 or 3 inches. How do I fix this issue? I have 7K more miles of warranty left. Is this a easy or hard repair? Thanks
Try disconnecting the battery and see if that doesn't fix it before you do anything major :)
Press and hold the switch until the window is all the way down and then hold it for 5 more seconds then do the same for going up It will relearn the express feature.
(Post 75340)
Thanks for the help CHRYSLER TECH! i appreciate it :) |
welcome
I tried the reset with no luck
It still comes up and I can get it to stay up until I let off the switch and it comes back down about 6 inches after holding for 5 second and longer. I tried several times. I'll try pulling the battery cable in the morning.
Thanks |
Window up issue continued
Well I tried disconnecting the battery and the problem continues. So we took it in to the dealer for a look and to have them check a few other things while its in. The wife has noticed a few other abnormalities, sometimes the seat doesn't adjust for her when she starts the vehicle up, other times it does. Her cell phone syncs automatically most of the time, once in a while it doesn't. The service rep immediately said it her iPhone that's the problem.
So at the end of day yesterday we called on the vehicle and seems they are stumped on the window problem and needed to keep it until next week. Here's my question to this list of experts (I get the feeling a few of you are in the business), this rigs 7/70,000 goes away in April its a 2007. She only has 35k on it now, its had all it maintenance, always garaged, what else should I be raising a flag on to have checked before the warranty ends. I'm concerned about the computer, especially with this intermittent key issue. I have seen these threads about door leaks and somebody else mentioned leaks from the sunroof down into the computer. Any suggestions would be very helpful, thanks in advance. |
unless u bought an extended warranty the 70 70 is for engine and transmission only.
Its the extended, bumper to bumper. Thanks
They fixed it, the regulator and the module were bad.
