BAS/ESP Light
My BAS ESP light is on. Any idea on what to do? I have heard so many stories about this.[:o]
RE: BAS/ESP Light
find out what the code is first then go from there
RE: BAS/ESP Light
Before doing anything I'd try this.
Start the car, turn the wheelALL the way to the left, then ALL the way to the right, then back to center. See if that takes care of your problem. This is actually a common issue with Crossfires if you have a dead battery, or removed the battery! |
come 2 a stop car turns off and battery and esp light come on
i went to go do my re do my whole interior, since then #1 he did a horrible job #2 he messed up my ignition skim module were it wouldn't read my key so it wouldn't turn on and he fixed that issue now that i took it out the shop now every-time i come to a stop my car turns off the battery light comes on and esp , my battery is brand new just bought one and when i have it at a stop and i put it on neutral and hit the gas my car doesn't shut off , i have not had a problem like this before i took it into the interior shop he did do my dashboard meaning he did have to take it off and @ the dealer they said that they scan everything and nothing is coming up so they said it might be a shortage where the wire is hitting ground not sure, so far i'm not driving it to be on a safe side intil it gets checked :confused:
my mistake his advice didnt correct my problem
