Tire Pressure Light
I just bought a 2005 Chrysler Crossfire last night, and the tire pressure light was on. I did check the pressure and added air to the one that needed it, but the light didn't go off. Any suggestions??
RE: Tire Pressure Light
If you equalized them with the recommended pressure (32 psi front/33 psi rear), the light should go out pretty quick. If it doesn't, go by the dealer and have them reset them. It takes a special magnet like thing to do it.
Congratulations on the purchase! A couple of other forums for you to check out are crossfirecommunity.net and crossfireforum.org. Same user name on all.......see you there. |
Hi - new owner of a 2004 Crossfire
Hello all:
New here, and new owner of an immaculate 2004 Crossfire, w/ less than 50K miles. In the category of "what's this, then ?", the drink holder will not retract. And would I be correct that the tire pressures should be 33 in the rear and 32 in the front ? |
The owners manual will have correct tire pressure information.
