04 Pacifica - HELP! Cluster in French
I got an 04 Pacifica and the cluster is in FRENCH [:@]unfortunately i cant read french...does anyone know how to convert it to english?
THANKS |
RE: 04 Pacifica - HELP! Cluster in French
On the EVIC...which are the buttons located next to the analog clock ....hit the menu button. One of the options is "language". When on English push the Step button to select.
if the evic doesn't work you might have to go to stealership to get the country code changed on your pac with the DRBIII tool
