05 abs light on...
Hi all, I just read through the entire forum and found a few questions similar to mine but no real answers. I have an 05 with the ABS on. I am guessing it is a wheel speed sensor. I see there is a TSB for this but what does that mean? Will Chrysler fix this problem at there cost? Is this something I can replace? I am just worried about a computer something or other. Any ideas how much this fix would cost? Thanks in advance!
RE: 05 abs light on...
unless the car is in warranty Chrysler will not cover a tsb just recalls are covered out of warranty
Need to find out what the code is for first. Before you can just go in there and replace a part we need to know that it will fix the problem. It might be a wheel speed sensor and replacing that may fix it. The other week though we had a car come into the shop with an erratic speed sensor signal, turned out the axle nut was left loose at another shop and the sensor couldn't read anything. Find out what the code is and we can start to fix it.
I had all the ABS sensors changed on my 05' last year. They say that they need to change them all if one goes.
