-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   06 pacifica drain plug leak (https://www.chryslerforum.com/forum/chrysler-pacifica-15/06-pacifica-drain-plug-leak-18818/)
jimbo74 Dec 27, 2012 07:58 PM
so... we have a 2006 pacifica, 3.5l auto
the drain plug is tight, or as tight as it will go, but it still leaks..... i htink at one point in time one of the fast places my wife took it to messed up the threads
what should i do?
currently looking at a few options... do i have any others?
full pan replacement
tap a new size plug
helicoil
what do you guys htink?
i will be doing the owrk, unless i can find a cheap reputable place to do it in the concord, ca area
jimbo74 Jan 1, 2013 01:33 PM
anyone?
Grenadiers Jan 1, 2013 01:36 PM
Try replacing the plastic gasket with a larger one, if that fails, try all of the above with Pan Replacement as a last option...
Cheers!!
jimbo74 Jan 1, 2013 02:21 PM
there isn't a platic washer on ours. there is a rubber seal set into the drain plug itself, looks to be molded in, it is crimped into a recessed grove on the plug
sadly, i think the threads are buggered up
dcotter0579 Jan 2, 2013 02:48 PM
You can buy a replacement oil drain plug at your local auto parts store. Try that first.
dodge10 Jan 7, 2013 02:45 PM
I had to get a new drain plug for the wives 2004 pacifica at autozone they dont hold up very well always had the oil changed at the dealer. You can buy the washers there too it will just be like a double seal try that.
jimbo74 Feb 6, 2013 02:34 PM
it is getting pretty bad now. it isn't the drain plug. i have bought a time-sert kit for it i got of amazon... it wasn't cheap, but it was cheaper than a new pan.....
now, just time to do it.. as soon as work lets me have some days off......
