06 Pacifica window fog
I purchased a Pacifica this summer and now that is has got colder and I have to start using the heat I get a lot of window fogging, just wanted to know if others are experiencing the same thing?
the external air entry door is probably stuck in the closed position. Unplug the battery terminal for 10 minutes, then reconnect. It will reset the system.
Thanks Desperado, I will give it a try.
I tried disconnecting the power from the battery for 10 minutes and still am getting fog. It is from not bringing in outside air.
How do I access the flap that closes off outside air? Is it solinoid or motor driven? Thanks in advance. |
