'07 Pacifica Heater problem, PLS HELP!
My '07 Pacifica has developed a strange heater problem. :confused: It will send heat to the driver's side vents, Dash or Defrost) but not to the passenger side. Has anyone had this issue? Any Chrysler service pros have any suggestions?
Thanks |
May have a faulty or stuck blend door or blend door motor which is not opening the flaps that allow the air to be distributed appropriately.
Thanks ChryslerCares, it does have "Dual" controls, one for the driver's side and one for the passenger side. Could this have anything to do with it?
locate the pass blend air door motor remove it and move the door manual if the temp changes as U move it then the door is fine U have a motor/wire/ac controls head issue then
(Post 65298)
