-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   07 Pacifica Navigation System Issue (https://www.chryslerforum.com/forum/chrysler-pacifica-15/07-pacifica-navigation-system-issue-15291/)
golfmarshal Jul 16, 2011 07:36 PM
All,
The navigation system for my Pacifica is saying "error reading disc" and continues "Loading..." for a couple minutes then turns off. My wife had pressed and held, she thinks, the NAV button and it reset the system and then was working for a day or two, but then went back to this same problem. Is this a problem with the NAV DVD in the back of the car? Does anyone have any suggestions? Thank you much!
golfmarshal Jul 18, 2011 07:15 PM
Navigation Issue
Does anyone have any suggestions for me on this? 62 views to date and no ideas? Please help...I am on standby. Thank you all!
shaka38 Jul 22, 2011 05:24 PM
It sounds like the disc is defective. Have you attempted to clean the disc? Have you tried to play a dvd in it to see if it will load? I'm not certain if it is only for the nav disc or if it'll play movies. See what happens with the disc in your entertainment center to see if it loads or gives the same symptoms...? Just some thoughts and a response, not just a view.
Good Luck!
golfmarshal Jul 23, 2011 01:53 PM
Nav Issue
Thank you for the reply. I have tried 2 different model # nav discs with and experienced the same issue - model AE and model AH. Could the DVD player in the back end of the vehicle where the nav disc loads be the issue? Thoughts anyone?
shaka38 Jul 24, 2011 11:57 AM
that would be my guess golfmarshal.
