07 Pacifica vibration- rear end
Old Nov 3, 2011 | 11:52 PM
tcook726's Avatar
What do you charge for the coupler?
Old Nov 4, 2011 | 06:12 AM
Tutts.inc's Avatar
Default Pacifica driveshaft coupler
The couplers are $300 each. We are located in Toronto Canada.
Old Nov 7, 2011 | 04:45 AM
FIPHOU's Avatar
From: SAINT ANDRE DE CUBZAC 33240 NEAR BORDEAUX FRANCE
MANY THANKS, but already i change the tires and problems are finished, thanks a lot. (if i have any problem again, i know that you have it !)
Old Nov 25, 2011 | 09:23 PM
tcook726's Avatar
How would I go about purchasing a flex coupler for this vehicle? Do you have a website to use? I want to use a secure way of paying for the part.
Thanks!
Old Nov 26, 2011 | 06:45 AM
  #15
Tutts.inc's Avatar
Default Pcifica driveshaft flex coupler
We are Firestone / GoodYear Tire and Automotive center in Toronto.We don't take web orders, but you can look us up under Bridgestone Firestone or Goodyear dealers in Toronto Canada. Look for Tune Ups to Tires inc. 2749 Dufferin st. Please call or email to arrange purchasing. 416-784-9988. firestoneondufferin@hotmail.com
Old Mar 28, 2012 | 07:29 PM
  #16
tripleamotors1956's Avatar
Default flex coupler needed
how do i get in touch with you to order a flex coupler? i am in need of one at the moment. thanx....... scott@tripleamotors1956 my email is tripleamotors@comcast.net phone 570-326-1769 ask for Al or Scott
Old Mar 29, 2012 | 06:36 AM
  #17
Tutts.inc's Avatar
Default Pacifica vibration
The AWD Pacifica drive train is extremely sensitive. You need to make sure the differential and the transfer case are in good shape. Check the condition of the fluids. Tires must be exactly the same, including tread wear. All of these will cause a vibration as well as occasional noise. Drive train problems and uneaven tires will tear the coupler apart. If the tires are uneaven, you can try puting the 2 better ones on one side and taking it for a drive. If the problem improves, you will need to get a set of equal tires. Check the coupler bolt spacing. The bolts should have equal spacing. I cary the replacement couplers without the drive shaft. I can be reached at 416-784-2984 email; firestoneondufferin@hotmail.com
Old Dec 20, 2012 | 02:10 PM
  #18
hectorAB's Avatar
hey do you stillhave that coupler i am having the same problem with my pacifica and i took it apart and that rubber coupler is destroyed i was wondering if you can sell it to me please email me Hectorayala26@hotmail.com i really dont wanna pay $1500 dollars for the whole thing thanks
Old Dec 21, 2012 | 06:10 AM
  #19
Tutts.inc's Avatar
Default Pacifica drive shaft coupler
You may have a problem with the coupler. You need to have a look at it. Check the spacing between the bolts. If they are not equaly spaced, the coupler has collapsed. I have them in stock. You may also have a drivetrain problem. If the coupler is good, you will need to check out the diff and transfer case. Regards.
Old Dec 21, 2012 | 06:12 AM
  #20
Tutts.inc's Avatar
The couplers are $200 each plus shipping. I can either put it in the mail send by courier of your choice.
