2003 Pacifica wiring
Good morning folks. I'm working on an early Pacifica (4th month of 2003) and it looks like the wiring colors are different from the 2004 up models. I'm looking for the crank, cam, map and tps sensor wire colors and pin-outs. Does anyone have them? Thanks, Wally.
Wallus, can you give me your email and we'll try something for a wiring chart. Thanks. *BW*
Thanks Barbara. I found the problem by purchasing an Alldata subscription and downloading the pin outs and diagrams I needed. Four wires were worn through where the harness goes over the left side of the trans. Was getting codes for TPS, MAP, Crank and Cam sensors. It was reving up and down, stalling then finally no start at all. All those sensors have wires running through that area and it was easy to see the damage once I took the left hand side of the car apart LOL. Thanks again for getting back to me though.And "Hooray Alldata!"
Success ! Sounds really good I'm sure ! Hope you took some good close-up pics for others to see when you post them. Could worn motor mounts and engine/trans movement have caused the problem with the wires too ? *BW*
