2004 Blower motor issue...
I've read a lot of the posts dealing with this, and "kicking it" seems to provide a temporary fix. It still isn't working. I've had a number of issues with my AC/heater front blower motor. I dealt with the bad resistor, which is now replaced. So that means the blower motor isn't blowing full blast the whole time.
If it blows full blast the whole time without the resistor, why wouldn't the new resistor be able to control it to blow as directed? Right now, after kicking it, it spins and is mostly controlled but sounds sick. It buzzes, and my latest drive tonight to dinner, it changed speeds randomly. I'm good with replacing it, if necessary, but I wonder if it's truly the motor or one of the wires or a bearing issue. |
I'd change it. Just get 1 off a Caravan (2003-2007) from a srap yard. Its the same part. There cheap, so if it turns out not to be the part, not everything is lost.
I'm with you on that. The scrap yard isn't good where I am. The only one nearby doesn't seem to have anything compatible. At this point, I'm curious as to the blower's behavior.
I'd say probably the bearing is going. My blower motor seized on me during the winter last year. I guess from all the dampness/heat, then damp again, rust forms on the bearing. Maybe try removing it,spray a little bit of WD-40 and that might fix it. When I installed the new blower motor, i put some on for good measure.
The blower was whining in ours and I replaced it. kind of a PIA because I was upside down doing it working under the dash but overall not THAT bad.
Originally Posted by cirrus98
(Post 85289)
Now if I can just figure out why my oil light is on. #newProblemAfterOld |
Originally Posted by Jwrbloom
(Post 85360)
Yeah...might not be a bad idea. I've already tested the new blower motor, so I know it's very different. The car is 10 years old, so it's probably time for a new blower motor.
When you say the sender kit, you mean oil pump?
(Post 85364)
I've been told that PACs are bad for the oil light. I changed mine, and 3 months later(warranty is up), light comes on again. Looked around and everything sells the same thing. there is no high end model.
