2004 crank swap 3.5 to 4.0
Old Aug 6, 2023 | 03:03 PM
Dark souls express's Avatar
Default 2004 crank swap 3.5 to 4.0
I’m looking at doing a crank swap from 3.5 to 4.0. I want to beef up the performance a little. Has anyone done this here? Looks like the crank will bolt up with a bearing change, do I have to change the rods also? Or should I take the pistons and rods?
thank you in advance!
Old Aug 10, 2023 | 09:08 AM
FIREM's Avatar
Not sure about the crank swap fitting in the block.
This swap required either cutting the crank or block main bore for the shaft to fit.
Pistons and rods are different to accommodate the longer stroke also.
https://300mclub.org/forums/viewtopic.php?t=25031
Bobcz
Sep 3, 2015 06:54 PM
thechef1959
Jan 9, 2015 09:12 PM
markkovacic
Sep 7, 2013 06:02 PM
GMON
Nov 19, 2012 06:34 PM
pmjolsness
Jun 2, 2012 05:11 PM
