2004 No Start, code Crank Sensor, replaced same code
I'm trying to look over this fair priced 2004, the lady said it ran good, recently had tranny and radiator replaced. When she got home one day the drive way it just stopped. Thought maybe something stupid didn't want to mess with it. I researched a little checked ground at the tranny since it had been replaced and the ignition coil her nuts were stripped so I didn't pull them out to see if I had spark. I could smell fuel in thr intake but to be sure her gage wasn't faulty I added some more fuel and I hear the pump turn on. All the fuses and relays seem to opperate. All homework led to Crank Poston Sensor. There was no battery in the car so everyone said I was out of luck for the codes, but I bought a cheap scanner anyway, erased the 4 codes and tried again. I got 2 codes twice, on about 02 sensor and one bad crank angle sensor. It was a 2 day project getting the sensor out which I broke less than even flush with the bellhousing. Used tranny I assume it sat outside but it was very very difficult to remove. Put the new one in, all back together still wouldn't start. Still spit out the same codes after Deleting? Any help??
