2004 pacifica wont start
Good morning everybody.. I have a tough one for ya. I have a 2004 chrysler pacifica that wont start. I have full battery power, tried replacing the starter and still no go. The relays are good in the fuse box... I am out of ideas.... any suggestions?
hey fellow 04 owner.
take a pair of jumper cables and connect from the negative battery terminal to the engine block. use both the black and the red cables (more connection). this should work, temporarily, and then you will know your negative wire is no good. happened to me and several others.
the fix is a good sized wire directly from negative terminal to one of the starter bolts. (i used a 4 gauge) it starts like it never started before.
Petermichael you sir are a genius! That was exactly what the problem was! Wow what a job getting to that starter though hey, there were more than a few curse words after finding out I didnt have to replace the starter but went through all the aggravation! Thank you very much!
I am also having a problem with my pacifica..i has been acting funny for a while, sometimes it would start right up, other times it won't turn over at all..no today I can;t get it to start at all...thought maybe the ignition switch was going out, but don't know what to try
Ground wire no contact to block
, would not let the PAC start
$1.98 at auto parts store, new copper end and it is all good now, starts with not problem.
Take off the drive side tire, and remove tired shroud thing. I just pulled it to the side. Oh yeh, lefty loosey, Righty Tighty. lol
