2004 Pac's Headlight Lenses have "crazed"
Hi, I am the original owner of an early 2004 Pac , it is garaged at home, but out in the elements ( Houston) at my office. The paint & trim is holding up well, but the headlight lenses are looking bad.
I want to emphasize they are NOT yellow. They are pitted and crazed to the point that they are beginning to look a little like frosted glass.
I have already tried the anti-yellowing paste, it makes them look "wet" for an hour or so, then it's back to looking bad again.
I want to replace them. Here's my question. Do I have to replace the whole headlight assembly, or is it possible to just remove and replace the lens cover ?
Thanks.
Thanks.
here are a couple of links for a set found on ebay while looking for something else, but the price seems reasonable.
http://cgi.ebay.com/ebaymotors/2007-...Q5fAccessories
hope this helps
hope this helps
teamfatmouse,
Thanks for the links, I will continue to look on ebay, but the posts on ebay are for 2007/08, which is not compatible with the '04.
In 2007, the Pacifica received a mild facelift on the front end, consequently the headlight assemblies are not compatible.
Thanks again !
Brooks Davis, aka steelydanfan........
Thanks again !
First of all tape off around the headlights. You can start with around 300 or 500 grit sandpaper. It will turn the headlamps white. Then work your way back up until you are using 2000 grit and finish off with a polishing compound with appropriate applicator. Then you can seal it with a plastic sealant or clear coat.
Or you can use one of so called 'all in one headlight restoration kits'. Look at the following link:
http://blog.vec.com/2010/07/19/revie...-kit-epic-win/
Also look at the ebay item # 350320921410 to prevent headlights from getting hazy again.
Well the original poster is ready to replace his headlights anyway, so what is the harm in trying these tricks? At worst he would damage the headlights, so he still can go out and buy new ones, right.
I am 150 miles north of your town.
Agree with you Chrysler Tech, the kits don't really work. My lenses are "crazed," I mean millions of little star shaped lines that appear in the lenses. Some of these craze lines look like they go through the lens, so to get rid of them, the whole lens has to go.
It is a shame you can't just replace the front lenses, the rest of the assembly ( which is about 95%) is still good. Talk about filling up landfills.............gheeez...............
Mine are starting to look bad too. I have around 63K miles on my 2006. I know most of the reason why is winters and gravel roads in Iowa.
I was thinking about replacing them with OEM xenon, but am not sure if they are a direct swap.
Unrelated and speaking of Iowa winters, I am also waiting for my exhaust to rust off. It looks bad.
