bmccaslin |
11-27-2017 09:45 PM |
2005 AWD 3.5L...tranny issues
Have a 2005 AWD Pacifica that is giving transmission problems. There is no reverse, but when you shift to reverse and rev the engine a little you can feel the vehicle rock as if it wants to move. Second issue, when put in drive, vehicle takes off fine but when it shifts to second it just revs. Will not down shift back to first. Turn off the key, restart and it will start back in first...has the auto stick shifter, I can drive this vehicle all day long in first gear. Any suggestions? There are currently no fault codes but my scanner did show a pending fault of p0700, a generic transmission code I believe.
