2005 Chrysler pacífica oil into cooling
Does you vehicle have an engine oil cooler in the radiator tank. Drivers side tank has a transmission oil cooler in it, some also have an engine oil cooler in the passenger side. Oil pressure is higher than coolant so if it is only oil in the coolant that would be first suspect.
