-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   2005 Pacifica 3.5L battery drain (https://www.chryslerforum.com/forum/chrysler-pacifica-15/2005-pacifica-3-5l-battery-drain-20034/)
ronney99 Jul 14, 2013 10:24 AM
My battery drains over night. My ohm meter says there is a 2.56 amp drain.
I pulled out fuses 46, 47, 48 and 50. Now it has 0.0 drain. These fuse go to the panel lights, door stero, Cluster, HVAc, clock ect.
Question: How would you suggest I track down the battery drain problem from here? :)
CHRYSLER TECH Jul 14, 2013 10:35 AM
get a wire diagram and go fuse by fuse see whats on each fuse and if there are hard items like switches or modules unplug one by one until the drain is gone then u have found it .
ronney99 Jul 14, 2013 10:46 AM
Thank you Kevin.
Should I purchase a wire diagram from Mitchells?
CHRYSLER TECH Jul 14, 2013 10:06 PM
there all the same
