2005 Pacifica Touring rear HVAC technical question
Old Jul 2, 2025 | 01:32 PM
OHowIH8OhioSt8's Avatar
Default 2005 Pacifica Touring rear HVAC technical question
Can anybody advise whether the 2005 Pacifica Touring 3.5 V6 has a second mini-A/C evaporator and mini-heater core somewhere under the center console for the rear HVAC system, or simply a blower that merely boosts airflow through ducts that originate up front? If the former is the case, where do the A/C lines run?
Thanks in advance.
Old Jul 2, 2025 | 02:38 PM
If you have duel air the evap and heater core will be in the back
Old Jul 6, 2025 | 03:04 AM
Can you advise where the lines to the rear evaporator and heater core can be found? Like inside under the carpet, or outside, or whatever?
Old Jul 6, 2025 | 09:35 PM
Outside usually on the pass side
TheTatesDecided
May 2, 2022 06:15 PM
azpac05
Aug 6, 2020 10:38 PM
momhatespacifica
Sep 10, 2013 08:12 PM
mustardmadman
Jun 19, 2011 12:48 AM
gerg
Apr 14, 2010 04:16 PM
