-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   2005 Pacifica Touring rear HVAC technical question (https://www.chryslerforum.com/forum/chrysler-pacifica-15/2005-pacifica-touring-rear-hvac-technical-question-35717/)
OHowIH8OhioSt8 Jul 2, 2025 01:32 PM
Can anybody advise whether the 2005 Pacifica Touring 3.5 V6 has a second mini-A/C evaporator and mini-heater core somewhere under the center console for the rear HVAC system, or simply a blower that merely boosts airflow through ducts that originate up front? If the former is the case, where do the A/C lines run?
Thanks in advance.
CHRYSLER TECH Jul 2, 2025 02:38 PM
If you have duel air the evap and heater core will be in the back
OHowIH8OhioSt8 Jul 6, 2025 03:04 AM
Can you advise where the lines to the rear evaporator and heater core can be found? Like inside under the carpet, or outside, or whatever?
CHRYSLER TECH Jul 6, 2025 09:35 PM
Outside usually on the pass side
