2005 Pacifica. Tried to jump, car now totally dead.
Hi guys.
The battery went dead. Got a friends car over, hooked up the jumper cables. Pacifica had power (courtesy lights turned on, mileage on dash displayed, clock was running). Gave it a few minutes to build up a little bit of a charge. Turned the key. There was a single click and then EVERYTHING went dark again. No lights, no clock, no *nothing*. Got back out, re-checked all the cable connections -- still no power. Shut down the other car, unhooked the cables. Checked all the fuses under the hood - all good (damn tough to get those tiny fuses out!!). Obviously no way to check the relays, though. Any thoughts or suggestions on what happened? This is a bit urgent, racing the clock somewhat. Thank you! |
replace the battery
Thank you for the suggestion,
I didn't consider it because the battery is less than 2 years old. So even when another car is hooked up and supplying power to the vehicle, a bad battery can prevent everything in the car from getting power? I only ask because I've never seen that before. Thanks again! |
a battery with an internal short will kill things quick.... all the jumping in the world won't help you.
Thanks guys!
Well I went ahead and disconnected the battery, and hooked up the battery from the donor car... sure enough, everything lit back up.
Definitely a learning experience for me, I was thinking the electrical system had just taken a dive! Sadly now... when I try to start it, it's just a very rapid metallic clicking from under the car. So I think the starter needs to be replaced next. Thanks to both of you! |
is your donor car battery crap? that is a weak battery with the fast clicking.
Again replace the battery with a GOOD one from the store. |
Thanks again for the info!
No, it's a good battery, BUT it might not have had a solid/good connection - which fits. I'm just hesitant to buy a battery for it right now and find out it doesn't work. I'll give it a shot! Thanks! |
replace the battery
Hey guys,
just wanted to hop back in and say thanks. Battery replaced and everything worked! I'll be honest, I was shocked, I've never seen that kind of behavior before - learn something everyday!! You guys probably saved me a tow and paying someone to do a diagnostic on top of the simple battery swap. Thanks again!! |
Glad it worked out in the end.
Something so simple as a battery causing so much grief..... |
