2006 no low beam on passenger side
Any info. would be much appreciated, already replaced bulb/element, drivers side low beam works as well as both high beams. Thanks.
possible front control module or IPM
Thank you , is there a way to check the control module or IPM.
not with out a good scanner
Take the four screws out of the FCM, unplug it and plug it back in. The problem is where the 2 pieces mate together, it's really difficult to pin down which is the culprit.
Thank you I'll try that.
FCM removal
Is it necessary to disconnect the battery and will unplugging and replugging the FCM require something to be reset with a scanner or to clear codes. thanks very much.
Yeah disconnect the battery before you do it. It will set a bunch of codes if you don't. No scanner needed.
Thanks again you guys are great.
Where is the FCM front control module located.
