-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   2006 Pacifica hard starting (https://www.chryslerforum.com/forum/chrysler-pacifica-15/2006-pacifica-hard-starting-11685/)
Rob_Alan Jun 13, 2010 04:04 PM
Hi. I have a 2006 Pacifica Touring 3.5L AWD. What I have is hard starting after it sits awhile. Fuel pressure is 62psi with key on. I have no signal to the injectors or spark,until after I crank it about 4 or 5 times. Then spark and it fires up. But it leaves a code. P0335. I replaced crankshalf/cam sensor. And it did not help any. I think the code sets because of cranking it so long. After it starts and I clear code,it runs and drives great. But if I leave code set,it will not go over 25mph. Like it's in limp mode. I check all ground that I can see. Also,if I turn key on 5 or6 times without starting,then go to start,it fires up. Like a fuel problem. But pressure is at 62psi at first turn of key. Like it's in a sleep mode. After 4 or 5 cranks it wakes up. I'm leaning towards a pcm. But not sure. Any and all help is great. Thanks. Rob
karfreek Jul 21, 2011 10:26 PM
Any ideas? I am having this exact problem. It has to Crank 3-4 times before it starts, or hold it on one long crank for 10 seconds and it stumbles to start.
Jay
