2006 Pacifica TPS reset
How do I reset this? I had to buy a new tire and now it constantly tells me to reset the system. I find it hard to believe every time you rotated tires or fixed a flat you would have to take it to thedealer as the manual says.[/align][/align]thanks[/align]
RE: 2006 Pacifica TPS reset
you need a round magnet that goes around the valve stem there is a sequence to do need to take to the dealer
the 04 and up will relearn if the tires have been moved. U say that some one replaced a tire?? most of the time when i see some one do that they snap the sensor when they reinstall the tires.
What does the sensor look like? it was just a small item at the bottom of the stem? Was it supposed to have a black box like I see on the internet? We looked inside the tire and did not see anything so we assumed the small (looked like a lead fishing weight) oval at the end of stem was all there was to it. Is there a way to turn off the notification? I don't care if it works I would just like to see my compass and MPG.
the tech cn tell you more
the main part of the sensor is inside the tire where it will read pressure. The stem will be hard and wont more. And no u cant turn it off its a federal goverment thing.
