-   Chrysler Pacifica (https://www.chryslerforum.com/forum/chrysler-pacifica-15/)
-   -   2007 Chrysler Pacifica ABS CEL Brake Light On + Speedometer not working (https://www.chryslerforum.com/forum/chrysler-pacifica-15/2007-chrysler-pacifica-abs-cel-brake-light-speedometer-not-working-28851/)
Nate Hawkins Jan 26, 2018 06:59 PM
On my drive home last night my abs light, traction control light and speedometer stopped working while making a turn on a off ramp. I drive home still brakes still feel ok. Now this morning I start the car and the Brak light is on also with all the other lights and the speedometer still is not working. I replaced both speed sensors on the tranny input/output sensors. Does the Pacifica have a rear sensor on the differential? Or could this be a issue with the rear wheel abs sensors that mount on the wheels?
Nate Hawkins Jan 26, 2018 07:03 PM
Also to add the P0501 code was coming up also. Basically a P0501 trouble code means that the vehicle's speed as read by the Vehicle Speed Sensor (VSS) is outside of the expected range (too high or low for example).
