2008 Pacifica Intermittent Hard To Start
At my wits end. Have had an intermittent hard to start prob w/my ‘08 Pacifica LTD 4.0L since 20k mi (now have 133k mi). 5 diff Chrysler dealers & 2 independent mechanics have been unable to fix it over the yrs & have charged me thousands of $ claiming they can fix it. I’ve now replaced the battery 7 times, battery cables, ignition switch, new spark plugs, multiple load tests, checked ground wire issue, all to no avail. There is no rhyme or reason as to when/why it happens. It always starts eventually..just doesn’t turn over right away. I’m hoping someone in the forum can ID cause.
It's was doing the same. Turns out it was the small wire coming off of the starter. It had gotten to close tho the exhaustmanifold resulting in the insulation melting and causing it to arc. Perhaps this will help. Good luck
Is that a design flaw? How much did that cost to fix? Seems crazy you can have a pervasive prob like this, never get any trouble codes & all the certified Chrysler mechanics that have looked at my car over the years not check for the issue you’ve described.
Originally Posted by Silverskates
(Post 111804)
Almost all dealer techs are paid by FLAT RATE TIME ...wire repair does not pay well and for an intermittent problem at that. YES I know very well how frustrating it is for the vehicle owner....I've been there, done that on BOTH sides of the coin! Good luck to you, and I hope the posted suggestion will take care of the problem you face. |
Ok...thx! Meant to ask if you think would be something covered under my lifetime power train warranty??
(Post 111809)
Thx much for your help! I’ll call a Chrysler dealer to find out if that part is covered under my lifetime warranty & pray that’s what’s causing this hard to start condition.
