AC issue :-(
Could someone please tell me location of ac evaporator in 2007 Chrysler Pacifica touring edition 4.0 the guy at Pep boys tells me the condenser on passenger side has leak. I have a feeling he means the evaporator not the condenser and if anyone has diagram or manual to share even better. thank you all in advance
the evap is in the dash the condenser is under the hood
The A/C evaporator is located within the HVAC housing, behind the instrument panel. The A/C evaporator and insulator are positioned in the HVAC housing so that all air entering the housing must pass over the evaporator fins before it is distributed through the heating-A/C system ducts and outlets. However, air passing over the evaporator fins will only be conditioned when the A/C compressor is engaged and circulating refrigerant through the A/C evaporator.
The A/C evaporator tubes are connected and sealed to the A/C expansion valve by use of rubber O-rings and a tapping block. The A/C evaporator can only be serviced by removing and disassembling the HVAC housing. The A/C condenser is located in the front of the engine compartment behind the front fascia. The A/C condenser is a heat exchanger that allows the high-pressure refrigerant gas being discharged by the A/C compressor to give up its heat to the air passing over the condenser fins, which causes the refrigerant to cool and change to a liquid state. The A/C condenser is equipped with two fittings for the refrigerant lines, an integral automatic transmission fluid cooler with quick-connect fittings for the transmission fluid cooler lines when equipped with an automatic transaxle, mounting brackets that attach the condenser to the radiator and an integral receiver/drier with a replaceable desiccant and filter assembly. The A/C condenser may be removed for service without removing the radiator from the vehicle. |
