Air conditioning motor
If anyone has any information, send help!!!
My motor is functioning for a short time, but then will kick out. If I tap the motor, it will kick back in and run for as long as I have the engine running. Again, once I shut off and then start the engine... nothing. I’ve tested all the sensors and regulators attached to it and it seems to be more of a motor issue but I cannot figure anything out. |
What year is yours? But from description, sounds like a classic case of a dying interior fan motor(can we say "replacement time"?).
Mine is a 2008 AWD Limited. Replacement of entire fan or is there a way to just do that interior part?
Are you referring to the fan located underneath the dash behind the glove compartment?
Yes the interior HVAC fan. And replacements normally come with the "squirrel cage", original ones tend to break trying to separate from the motor. Have FUN doing the job, I recently did my 04 T&C for same type problem! A little patience and perseverance and a warm indoors work location will save you lots of labor costs as the blower motor is not that expensive a part. You are referring to your interior ventilation system blower fan ... CORRECT?
Thank you.
That’s the part! I’ve looked it over in the past and thought I may have had a bad part. When I checked the voltage, a good shock ran it for some time without any issue. I’m guessing it beginning to fail again and you’re reply has been exceptionally helpful!!!
Sounds like you and I tried the same things, just different models of vehicle. Replace that fan motor assembly and you should be "good to go"!
